brake fluid leak
primo
there's a very slow leak coming out from the rubber seal of the right (front) brake lever (master cylinder?). its a cb350 and i rebuilt it with a new kit (seals, spring, etc) but it still leaks a little over a course of few days. did i make a common mistake in the assembly? help
Perhaps you've put the seal in the wrong way around? I haven't re-built a CB350 MC, but all the other one's I've done have a "cup" shaped seal that goes into the bore concave first.
Also, have you cleaned out the spring area properly after assembly? Might just be residual fluid seeping out? Flush the outer with brake cleaner and see if it still leaks.
