Brake Light issue....
mudchicken
Active Member
Well I have to admit Im a little embaraced to ask this question but Im at my wits end and cant seem to figure it out. I bought a brake light from Dime City. http://www.dimecitycycles.com/vintage-cafe-racer-caferacer-bobber-brat-chopper-custom-motorcycle-lighting-parts-slanted-chrome-cats-eye-taillight-62-21605.html The issue I am having is my stock harrness for the brake light has 3 wires. Red (constant power) blue (power when the brake is applied) and black (ground). The new light has 3 wires. Red to the buld yellow soldered to the frame and black to the bulb. If I hook them up red to red yellow to blue and black to black It lights up but I dont notice a change when brake is applied. The other thing I found if I run just the red wire all other wires have power to them including the ground wire. If I hook the red and yellow I get power to the ground and the bracket. Im lost I checked all my brake light switches and they are working correctly. Anyone have any ideas? Im ready to jump over this thing. :'(
I would guess that yellow needs to go to your ground and red is the brake light. That leaves black as the running light?
I agree with sonreir, because if yellow is soldered on there it would make sense to be a ground. Odd wiring colors though?
Yeah thats kinda what I thought. I did the yellow to the ground red to red and black to blue. I get no light but everything is getting power including the bracket. I dont know if I tried the red to blue yellow to ground and black to red. I will see what that does. On another note after I posted this question I went to the garage and grabbed the old light. I pulled the ground wire off cleaned it up and plugged everything in like it should be. red to red blue to blue and black to black. The light lights up but It does nothing when I hit the brake. So I thought maybe I have a bad switch. I tested the line with nothing plugged in. Red is constant power and blue gives me power when brake is hit. I also checked front and rear switch no power when brake is off and power when brake is on. So I dont know if the blue is not giving me enough power or if something with the light is messed up. The other odd thing to note is when I had the new light plugged in (not sure how I had it) I had running light and a very dim brake light meaning it got slightly brighter when brake was applied. When I turned the ignition over to park (KZ should be just tail light) I get the running light. When I hit the brake it lights up real bright. So it works like it should when in parked on the ignition but when the bike is running I get hardly anything. Im about to pull the little bit of hair I have left. Its so frustrating for something like this to keep me from moving on after all I have gone through to get her running right. >:(
Ok let's treat the light and bike separately for a minute.
First, do you have a multi-meter / voltage tester? If not even one of those simple 'light up' screwdriver style test lights will serve you well.
Bike - using a stock light or better the voltage tester, make sure you're getting voltage to the wires you think you should at the right times.
Red = running light - should get voltage when you turn on the ignition - not just running the bike but when you turn the key on
Blue = brake light - should get voltage only when you pull the front brake lever or press the rear brake pedal. Try each on their own and both at the same time
Black = ground - should never have voltage, and should have continuity to the frame/engine etc. This is where a $10 meter comes in handy that has a continuity tester. But if you test the Red and Blue wires with a simple test light and use the black wire as the ground vs clamping to the engine or frame with the alligator clip on the test light then that indicates good ground too.
Light - based on you saying you're seeing voltage in the ground wire and light housing the first thing you want to confirm is that there is in fact continuity between the different wires - there should not be.
Red = running light - should be NO continuity between the Red wire and Yellow ground or housing of light.
Black = brake light - again no continuity between Black and Yellow or housing of light
Yellow = ground - should have no continuity to anything except the housing it is soldered to.
Remove the bulb for these tests. Test at the little terminals inside the bulb socket - let's see a pic of that. You can also test the bulb itself to confirm which filament in the bulb is running vs brake and which terminal they connect to in the socket to confirm which wire is which. You can also test the bulb for faults - maybe the continuity between the power wires and ground is happening inside the bulb itself.
Once you've nailed all this then you can connect it and shouldn't have any concerns.
I have both testers a multi tester and the test light with ground clip.(not sure why I have the multi tester being I dont know how to use it :-[) I tested the harness with the test light and I am getting constant power from red when ignition is on. I get nothing from the blue until I apply the front or rear brake. I want to check the light to see what wire runs what on the bulb. I will get on this tonight after work.
You sir are the winner!!! I thought I tried every way but I guess I didnt try your way. It works like a charm! Thanks for all the help everyone! This place is great. :)
I was going to chime in but you got the answer. I got one from dime city and it wouldnt work so I played different wire combinations and sure enough, black isnt ground. WTF?!!? oh well, got it working anyways
Black isn't ground on Honda, never has been in my experience (admittedly, I only go back to 1965 Honda's ;D )
Mr Honda's engineers decided BLACK is live with switch ON ;)
