brake lighting problem... PLEASE HELP
tomohawk
umm.... I swear I didn't know it was flamable.
I just replaced my ignition switch (actually just bent the prongs a little to make a better connection) and a turn signal, thats it. When I put her back together she runs great but... now my front brake wont light the tail light. the rear lights it fine, front does nothing and god forbid you press both brakes at the same time because if you do you blow the 15amp main fuse and she dies. Ive chased wires, poured over diagrams and I am at a loss here. What would make the brake light not work for one and why on earth would you blow the main fuse because of it?
PLEASE HELP!!!
RIDING SEASON IS ALMOST OVER AND I WANT TO GET A FEW MORE MILES IN THIS YEAR!!!
Geez, you got something touching somewhere. I would go back to the begining and check that ignition switch, maybe when you bent the prong you went to far and now when it's inserted into it's holder one of the prongs is touching the holder or another contact on the switch. Or when replacing the turn signal the wires that attach to the bulb socket is touching something metal. If you soldered the contacts on the bulb socket or wires leading to the bulb socket maybe a bit of solder slop is shorting it out. And check the grounds on those curcuits and make sure they're good. electrical stuff can be frustrating voodoo.
Terry
J'ville, Fl
