Brake / Tail light ideas or solutions??
MBS
Live, breath, sleep HONDA!
Hey all, I am need of some ideas for a brake/tail light for my racer project. I am using a fiberglass cafe racer seat with a round cowl. I want a flush mount light or something small - about 2" that I can use for both the brake light and tail light. The trouble is I am running a 6v system, so that limits my options to something I can put a dual filament 6v bulb into as I think LED lights will not work. It needs to be fairly cheap also. Please post pics and ideas. Thanks.
This isnt flush mounted, but it works great!!! I went to Advanced Auto parts and got a trailer marker light (pic below)
Out of the box it only has a single filiment bulb in it but it is VERY simple to swap that bad boy out for a dual filament connector and bulb (note you MUST change the connector in order for the dual filiament bulb to work). The light housing comes with an L bracket mounted to the back that is easily bent into a U that you can attach to the underside of your seat pan. Keep in mind that I used my stock seat pan (metal) for my seat base, but this should work just as well for a fiberglass seat cowl.
This is what she looks like mounted!
Total cost (Light/New Double Filament Bulb and connector) $5.50
Thanks for the reply, I have been considering that idea also. Today I went and looked at the lights (same thing you used) and its a possibility. So far the only idea I had come up with was the same setup. But before I went with it I was hoping for something flush mounted. Yours looks good and works well so I may end up doing that anyway. The ones I looked at were packaged and I could not tell how the bulb socket was attached, I assume a rivet? I did not buy it because I was unsure if I could switch the socket to support the dual filament. -MBS
I am going to use pair of dual filament markers and a trailer light converter to integrate brake and signal lights.
You can switch the socket out! On the back of the unit there is a little rubber sleeve on the single wire, if you remove the rubber sleeve the entire socket will slide out of the light housing to allow you to put in a dual filament socket.. very easy to swap them out.
Kevin
you may also check out a local truck parts distributor. big rig guys love their lights. also, they are often cheaper than an average auto parts store and are sure to have more choices. incidentally, i am using a nearly identical light to hecklejk, (in amber), for my turn signals. you cant beat'em for 6 or 7 bucks. replacable lenses, and who gives a crap if you drop your bike and break one. at least i am not out 50 bucks for LEDs or something.
later,
ryan
Funny you say that. Actually I went to the pilot truck stop last night on my way home from work and they have a much better selection with better prices. But I still did not see anything that I thought would give me the look I am after. And surprisingly a lot of the lights truckers use, are now styled the same but made with LEDs, price is right though and as I said before I am limited to what I can convert to a 6V system, which makes it harder.
i am using a stock set of harley front signals... any duel fillament signals will work... you could always just take your stock ones and swap them... you would not have front running lights but you would be able to use them as turn signals in front... then in back run your brake and running light to the other ones... done and done
hanly2 said:
I have a few idea's
JRK the harley signals are a good idea but I did something similar with ma last build, so I am looking for something different this time around. But its still an option. Hanly2 I like the oval light and the round flush mount one, any idea on what size they are and where I could get one? Price? Thanks for the ideas guys. - MBS
i think that some of those lights can be had from someone like http://www.taillightking.com/ i saw some similar, and i think it was this site that someone recommended over at sohc4. you have to search by make and model, but it opend up options, and some of the repro stuff is relatively inexpensive. quite a few have bezels as well, if that helps with flush mounting. you can rest assured, a lot of the stuff there is 6v. ;)
later,
ryan
I don't have enough time to do an exhaustive search at the moment but I recall coming across parts for hotrods in the past that were essentially tail light housing with intentionally thick lenses that would be mounted in place and then sanded flush with the surface. Does that make sense? Was I dreaming?
I have the same pointy advance auto tail light. i swapped the guts out of the stock cb125 tail light into that housing, and the 6v bulb as well.
the only Issue I have with it is that the 6v 1157 (i think that's the number) bulb is a little too tall for the housing. Still working on that one.
http://www.nostalgic-products.com/bigimages/nv12b.jpg
If you look at the properties for the picture it will show you the exact link to the site.
Great thanks, I'll check it out. Thanks for all the help guys, did not expect such a big response with so many options.
That triumph name tail light looks cool, but hard to make. Nice though, thanks! -MBS
http://www.alumilite.com/HowTos/TailLightMoldingNoEquipment.cfm
http://www.lowbrowcustoms.com/lowbrow-customs-diy-tech-tips-howto-cast-custom-tail-light-lens.aspx
