broke a bolt
cb 550 guy
have a good day dude
hi guys
i was trying to change my leeky oil pan gasket. Then the unthinkable happen. I broke a bolt :o. What should i do.
How should take it out
need help.
yasir
If there is enough thread exposed you can used two nuts tightened against eachother and remove using the inner nut only.
Otherwise (flush or recessed break) you need an extractor. Most tool shops have them... attached are Princess Auto's offerings.
Here's an explanation of how it works
http://www.newmantools.com/drillout/how1.htm
Of course this is going to be a bitch since I assume the bolt is on the bottom of the engine :P
I tried those goofy looking bolt removers recently and all it did was snap off and cause a lot more problems. Greg with Ohiocaferacers.com got it out so you would have to email him directly to see how he did it. I gave up just before trying dynamite.
often if you drill a small hole down the center of the bolt (easy to say hard to do) and then gradually open it up with a larger drill almost until the drill diameter is just smaller the ID of the threads the remaining "thread" will spin out
I forgot - you should try this first.
place a punch on the remaining stud and give it a good whackwith a hammer. this will sometimes "wake up" the bolt a then you can use a center and hammer to turn out the remainder by putting the cp near the edge of the bolt and tapping it counter clockwise
