busted bolt removale?
pyro139
1981 cb650c
k was tightening every thing up and snaped a bolt clear off with thread still in and nice smooth snap, what best way remove?
i was thinking drill out and rethread any one have easyer safer ways?
and its on my master cylynder handlebar clamp :-\
Get yourself a set of easyouts. You can get them from Canadian Tire or Princess Auto or just about any store that carries car parts or tools. You just drill a hole in the bolt and whack the easyout in with a hammer and twist it out. Works wonders on old rusty stuff, and since you just put it in, it should be pretty easy to get out again, right?
BEWARE of EZ outs! Snap one of those off and .....well it's scary.
I avoid them like the plague. I prefer using a center punch and hammer. Just catch the edge of the bolt and tap it counterclock wise. Failing that I drill out the centre starting small and going bigger. Usually you can relieve the pressure and they "walk" out while you're drilling.
+1 i use the easy outs on screws with jacked up heads on them and counter sunk screws (had to use this method tons of times in aviation) but once the head is gone yes drill the center as zixxer said.
Drilling and easy outs work well on old bolts.
Since you just put the bolt in, try using a strong magnet to turn it.
First punch the end with a proper punch and hammer to get a starting point for a drill. Then I'd drill out with a smaller bit - all the way through.
You could then try an ez-out, or drill partially again with a bit bigger bit - reversing and angling the drill a bit to get some bite on the way out might bring the bolt out with it.
Got a pic of the m/c? I can't recall how the bolt threads into it. If the hole for the bolt goes all the way through you can drill it out from the back end.
this one works sometimes, but use caution.Place a hex nut on top of the flush sheared bolt, and spot weld to the bolt,,as suggested drill thru and relieve the bolt and grind a punch or chisel to suit,,,start tapping!!!!!!!
