Buying cb750 1977 help
fly2devin
CognitoMoto.com
DTT BOTM WINNER
I'm going to go look at a cb750 tonight with 60k miles. What should I look for? How much is it worth? Has title and inspection. Looks like its been taken care but defiantly shows its age. Any advise will help.
Thanks
60k on the clock will require a motor rebuild if it hasnt been done already. If youre not ready for that, you should keep looking. Without more detailed info, and pics its near impossible to give much more advice than that. At best Id say $400 (if the motor hasnt been rebuilt).
If it hasn't been beat on and doesn't smoke it should be OK for 100,000 miles. CB750 is pretty understressed motor
If it was a CB350/400 it would be worn, CB500/550 would need re-build but will do 70,000 without issues (except oil leak from head/cylinder as 'O' ring goes hard and doesn't seal 100%)
True PJ, but the chances that the motor has been maintained properly and not beaten up on is slim (at least in my experience).
True, you know I 'like' engine work and hate painting so if it looked OK I would get it ;D 8)
So I took a look at it and it starts fine. Blew a puff of smoke at start up not sure why. No oil leaks and valid inspection. Little rust on frame and such but not bad. Didn't ride it but it idled and rev'd it a couple times. Fork was leaking from him strapping it down. He said a bike mechanic owned it before him and used the bike to commute to work. He said the motor has been taken down but was unsure of what had been done to it. Here is a pic.
It's a good deal with clean title for running bike.
Don't touch motor, just get fixed up and ride it.
Oil and filter change will be a good idea, full service even better.
CB750's are notorious for blowing puffs of smoke for absolutely no reason. Mine does it almost every time I start it, but it doesn't burn any oil what-so-ever. Like everyone else said, if it runs, leave it alone. Change the oil, maybe some new plugs and go through the carbs. Sync them and make sure your air/fuel screws are all adjusted the same. Replace the air filter if needed. Check the cables! Cables are so over-looked. Bleed the brakes and put some new fluid in the lines. Replace those worn out tires and that chain and sprockets. Sink a few hundred bucks into it and she'll serve you very well.
