Bypass handle bar switch
adriannarnold
Coast to Coast
Hey guys,
I am essentially trying to clean up my handle bars. I already removed the left switch as I no longer have turn signals.
Is there a way to bypass (remove the on/off switch) from the right side? I would like to just have the key on/off ignition. I know longer have an electric starter (not sure if that matters)
I would like to just get an aftermarket switch that is smaller and just has high/low beam and horn. Is the kill switch required by law? Can I just use the key? Also, I am assuming I need to upgrade my throttle as well.
Sorry for all the questions. Doing a bit of brain storming and am pretty new to this.
Thanks
Kill switches are required on bikes that were originally equipped with them. That's all I got......
hey dude, You can just move the switch.. I bought an aftermarket switch from princess auto and mounted it under the tank and hardwired the ignition to it... Im sure you can do the same with the kill or just hardwire it and keep using the key
my kill switch doesnt work, so I installed a little red button in the handlebar riser hole in the triple tree and wired it as a kill switch. clean and functional. got it at radioshack. just an idea.
Awesome! Thanks for all the info. I like the idea of moving it. Time to bust out the wiring diagram and find a good spot for it.
Thanks again
Hey man! Dimecity have a "retro look" kill switch for about $16. It is pretty narrow and unassuming and clips right on the bars. Cleaning up the bars is a concern of mine also so I also ordered an "all functions" left side housing as well. I havnt go t mine in the mail yet, but I figure that coupled with a new throttle lever and simple lever brackets on both sides will make it nice and simple looking. I was also thinking about just having a key start, but it's probably for the best, I'm too stupid to have a hardwired "on" switch, I'd surely leave the bike in gear the first 500 times.........
