Bypassing starter button CB500? Need help!
edelweiss
Coast to Coast
Hi,
We are trying to start a 72 CB500 barn find and she almost started, but it's getting tiring trying to kick start it. The starter button is missing on the right control. See picture below. Is there anyway to bypass this button via the wires on the right control or touch some wires together in the starter itself?
Thanks!
John
All you have to do is ground the yellow/red wire to switch the starter solenoid.
The yellow/red wire goes up through the wiring harness all the way into the right control housing (through connectors of course). Behind that little bent metallic clip is a small contact connected to the yellow/red wire. When you press the botton, all it does is make contact with the .....contact and close the circuit between the contact and that metal clip. That metal clip is attached to the control housing which is connected to the bars which are grounded.
In fact, if you could find a nail that fits in that little hole in the metal clip, you could just stick it in there to close the circuit.
If all else fails, just find the yellow/red wire in the harness somewhere and ground it whenever you want to run the starter.
Thanks. I used a paper clip and that did the trick. She started (after about 30 minutes)!
