Café Racer Project CB500 1977
Wimking
Hey Guys,
i have a CB500 Four as my new Project and want to make a Café Racer.
I'm form Switzerland.
I Dissambled almost the whole Motorcycle but now i have a Problem.
It's my first time that i work on a motorcycle so i have my first question^^
My plan is to make a grenn/gold theme café racer with short knuckles and the original brakes, etc.
At the moment i have a Yamaha Fork but i got all the Original Parts to Change ;)
I don't know which Year it is because i wait for the Papers.
i only have that pictures at the moment but i hope you can help me.
i want to put the motor out to start framework but the problem is i can`t get this bolt out and i hope you can help me.
The Bolt is here somewhere in the picture and its the last bolt that i can't get out.
i take a better picture tonight for you.
Thanks for the Answers ;)
Re: Café Racer Project CB500
Sorry that i didnt write this but the bolt is where i made the red line in the picture.
its the last bolt under the swinging arm that connects the engine and the frame.
Thanks for the Reply!
Re: Need Help! Café Racer Project CB500
normally the year is stamped into the neck of the frame or on the vin number tag (this can go lost due to loose rivets so don't wory if it's not there).
thanks yeah i got the vin number ;)
my only problem now is the damn bolt that i can't get out! i go to the garage tonight and make some pictures so you can see which bolt i mean ;)
Hiya mate if you have taken the other engine fixing bolts out ya need to undo the nut of this last one then take the weight off the engine cos at the moment it will be nipping up between frame and bolt use a car jack or similar under engine then use something to tap out the long bolt (like another bolt) tap from right side of motor to left side maybe even use a bit of lube to help it along let us know if it is more of a prob than that mate
^ Yup what he said. Not familiar with your model but I'm guessing all of the engine's weight is on that one bolt, relieve the weight using a car jack or similar and it will come out easily.
Clean looking motor!
Café Racer Project CB500 1972
thanks guys! yeah i put some oil on it and some jackstands the i could hammer it out ;)
nice, now i only need to flex the chain away and then i can put the motor out and start with the framework.
Thanks a lot ;) And i know now that the Year of the CB500 is 1972 ;)
So now that this problem is solved, here a picture for you from my tank and my vin number ;) more pictures will follow when i make some progress on saturday ;)
Re: Café Racer Project CB500 1972
Hey Guys next Question. I got a Problem to put my Engine out of the Frame.
The Problem is that the Bolts at my Breather Cover are destroyed by the stupid previous owner.
So did you know how i can put the engine out?
I tried everything out with laying down the motorcycle, etc.
The oil pan is out but the engine get stuck everytime i try to put it out. Any thoughts how i can remove the cylinder head without removing the breather cover?
Thanks for the Help!
Don't think ya can get head off with breather cover on as there are four bolts holding down the head inside the breather cover if the outer bolts are really shot drill them out start with a small bit workin ya way upin drill bit size till ya equal to the size of the shoulder of the bolt then it should come away
So my bolts are shot. But before i try to drill them out, any other advices how i can get my engine out? I got a couple of pictures for you guys! ;) what pieces did you remove to get the engine out? I got pics for you! Thanks!
Hey Guy i finally got the Six Bolts out after 4 Hours, with an Impact Driver, Hammer and a Saw ;)
Happy Days!
And on Saturday i try to get the Motor Out of the Frame so i can start Frame Work ;)
Hey Guys, i finally made Progress! ;)
The Engine is finally out of the Frame now lets Start Bodywork ;)
Have a nice Weekend everybody and thanks for the Support .
Sweet times mate ;) ya doin well always expect the worst :o then if it goes ok ,Bonus :P 8) av a great weekend mate , looks like we gonna have sunshine here in UK this weekend so time to ride yee ha 8) always here if ya need Q & A's :D
So a really Short Update.
I washed the Frame and Swingarm to finally can Start Framework.
i am not really sure if i can make it, but i want to make a Café Racer Seat and probably a Brat Seat so i can switch between Single Person and Two Person riding.
I think for the Moment i will stay with the Original Place of the Battery and Batteryholder.
I will start Welding and shortening of the Frame on End of July when i will have my welding lessons.
I want to get rid of my Center Stand and some other small Pieces.
Until then i will buy my shortened U-Bar for the Back and other small Stuff.
Motor is at the Moment at my Mechanic where he looks over it. He's a specialist for old Honda Motorcycles and a really nice Guy.
I made the decision to Sandblast and Powdercoat my Frame and Swingarm in Bronze.
Did you know where i can see a Bike with all unnecessary Stuff cut away for a Café Race.r As a reference so that i didn't cut the wrong sections out?
Hope it all works out how it should. My Deadline is the Start of Summer 2015.
-Wim
Hey Guys i finally made some Progress ;)
After a half year i finally made my Welding Course.
Soooo at first i started with welding my new Rear Hoop in Place.
Like this!
So now like ever my questions.
I want to get rid of some tabs.
i tred to mark it red so you see which one i mean.
did i can cut this or are they necessary for engine, etc….?
the first i think is for the side columns but i am not sure, if it this i want to keep it.
On the last two pics did i need to press that stuff out of the frame?
And the passenger pegs i think i need to keep to mount rear sets is that true?
thanks for the feedback!
as soon as i got it detabbed it i can sandblast the frame and send it to get powder coated! ;)
Next Updates should be here on wednesday!
Its so good to finally have my Camera back to take good pics of it :D
thanks guys!
yeah, just hack all that nasty stuff off, you don't need any of it :-\ cant you find more to cut off ? think of the weight you can save !!
thanks yeah but the side covers and the side column i wanna keep or should i ad a column later?
and the front triple tree stuff did i need to press that stuff out?
only if your going to put new bearngs,the stand pieces you should keep it is very handy having a side and center stand.... the center stand just put on when you need to work on the bike like change a tire
