Cafe 71 CB100 as seen in kileys garage
TurdFurguson
Weird Indy Kid
DTT BOTM WINNER
Putting this out there, if you went to barber this year you say her in all her glory. I think anyone there can vouch for the bike itself.
It is a 1971 CB100 Super Sport. I would really like to get 1500 out of it, as always I have a good amount more into it than that.
$1500 or trade for Running RD350+$/parts/guns/etc
index.php
index.php
index.php
I drove it the entire weekend down at Kiley's but those are the only miles that it has on it since its been re-worked. I had it up to about 50mph but there is still a little tuning to be done to get some more power out of it. There is a build thread you can look over in my sig, its full disclosure over there. There are some pics in the last couple of pages that are of it finished, I can get some more if you want to see parts of it. I will say that this bike is a blast to ride and every time i stopped people were asking about it, mothgils was kinda annoyed by this. The reason im selling is that I bought it so my wife could learn to ride, now she doesn't want to ride, so I want to try to get some money out of it to put into my 350 project or start an RD project. I have all of the parts that were taken off of it still that I will include as well as a CB125 motor that I was thinking about swapping over. You can take the crank, rod, cylinder, piston from the 125 and it swaps right into the 100 (or the 125 bolts directly into the frame). Then if you wanted you can take an XR200 cylinder and piston and match it with the 125 rod and crank and slap that in the 100 or 125 head and block to make a monster. Anyways, the 125 would need rebuilt but it'll be included along with an extra front tire. Ive got most of the receipts for it, comes with clear Indiana title.
The good:
Custom pin striping by Kit Headley
Custom rear hoop
Custom hidden battery and electronics tray
Full 6v ->12v conversion
12v stator
12v battery
12v regulator/rectfier (Oregon rectifier)
12v head/tail/turns/speedo lights
Full carb rebuild, include spare jets
New coil
New levers
New Ignition
Fiberglass seat with custom cushion
Motor was apart and new gaskets all around
All seals were replaced as well
New cables, speedo cable is impossible to find so i wraped it in shrink wrap to get it black and looking brand new, works fine
New tank mount rubbers
New Intake and Exhaust valves
Full head rebuilt was done by a local shop
New cylinder
New Piston
New Rings
New Drive chain
New tapered steering bearings
Fork rebuild
New tires
Tires
Rim Strips
Tubes
New headlight brackets
New mini speedo
New rear brake and main stand springs and pieces
New drag bars
New gas cap
New turns
New led tail
New front fender
Custom license plate bracket/rear chain guard
Custom rear turn tabs
New points and condenser
Im sure there are some other new small things things as well that im missing but you get the point
Clutch plates were (according to the manual) at almost full widths
Brand new front fender
New rear shocks
Custom paint, I'll include the rest of the base so you could paint whatever you want to match.
The bad:
Headlight bucket has a small hairline fracture and a chip out of the plastic
Small oil drip out of bottom of block
Still some tinkering to do with the tune
