Cafe Seat / Hose clamp method
zedmak
Hey,
I'm about to start my seat so I can get my bike on the road for spring. I'm going to be mounting my seat using the hose clamp method. I was wondering if anyone else has done it this way and been able to not have bolts sticking into my junk. The cushion I'm getting is thin.
http://www.dimecitycycles.com/vintage-cafe-racer-caferacer-chassis-seat-parts-one-up-bumpstop-race-single-seat-legendary-motorcycles-seat-foam-manx-thruxton-pa2502.html
I'll attach some photos for you to understand what I mean.
what i did to attach my seat was to "invert" that kind of method.
i fixed four threaded bars on the seat pan with 2 nuts (one on the top the other one below the pan) mounting them on a aluminium plate connected with the frame (between the tubes).
hope this helps.
There is a guy on here.. can't remember his name at the moment... But he sells things specifically for doing this.
Just my opinion, but that hose clamp method is not the best, plus in your case you have the bolts to contend with. Get some mild steel strapping, about 1.5 inches wide, and maybe 2mm thick, and fabricate some brackets to bolt the seat unit to the frame. You can bond, or glass the brackets into the seat unit easily.
What is the base of the seat pad made from? We put our pads on an alli plate, and attach it to the seat unit with rivnuts, which are shallow, or you can cut keyhole shaped holes, and use button head bolts.....also very shallow.
The hose clamp method of seat attachment looks similar to the gas tank post mounts that a lot of dirt track tanks use.
You can also use aircraft-type MS / Adel / P / cushion clamps, which would allow you to run a (round headed) bolt from the top. The potential drawback is most of the MS-style clamps are meant for a 3/16" bolt, but they're easily reamed out to take a 6mm bolt and still have sufficient material remaining.
If at all possible, use the largest washer possible under the fastener head to spread the load on the fiberglass and stop the bolt from pulling through the fiberglass.
Pat
