ctluba said:What do you mean??? This is a CB1100F oil pump set up. I used all the stock parts except for the cooler. As far as how the pump functions and handles oil flow, output and input etc, I let the Honda engineers worry about that.
Drain back....the pump may have the requisite check valve built in since it's tapped for lines. Honestly though, since it dumps right back into the sump I doubt any starvation would occur.thebronze said:What I mean is.... With the cooler the bike now takes more oil to fill right?? Well when You shut the bike off the extra oil that fills the cooler and lines will drain back into the sump..... Right?? Wrong??
