Cam chain problem cb350f
simplesence
Ive got a problem thats confusing the hell outta me. Ive got my engine mostly back together, the valves should be fine and the cam chain spins freely until i put the sprocket on the cam. The valve covers off, so the cams not doing anything but as soon as the sprocket goes on the cam the chain gets really tight at a certain point and seizes. this happens both forwards and backwards. Some tappet adjusters fell down my cam passage but I cant see why the chain would spin freely off the cam if there was something in the gears. hope this wasnt rambling or too confusing. id love to not tear down the engine again.. thanks a lot.
Groose said:
......Some tappet adjusters fell down my cam passage but I cant see why the chain would spin freely off the cam if there was something in the gears......
Err......what else did you drop down there??
... to my knowledge theres nothing else down there. the reason its torn down right now is because some of my tappet adjusters flew off while it was running. I havent recovered everything so im assuming something fell down hopefully into the oil pan. I just cant see why it would spin no problem until i put the sprocket on the cam. As soon as i pop the sprocket off the cam its spinning again.
Is it a new camchain? if so, do the have the right amount of links?
All the tappets out? No way the cam is lifting when you turn it?
Other than that, there might be something in the tensioner blade that has tightened it when the sprocket is on.
Same old cam chain, proven to work. valve cover/tappets nowhere near the bike. ive stared a hole in the cam while i turn it so im 99% positive its not doing anything unusual. Whats the tensioner blade? im new to this so ive only got the manual terminology being the slipper and the guide both of which are out of the engine.
hillsy said:
You must have had something fall into the bottom end.
Tensioner blade is the slipper.
NOPE, tensioner blade is the tensioner, slipper is the guide in front
It wasdecided in the other post that cam riming was out and valves are hitting pistons (better explanation in engine section)
Nope, I've seen it a multitude of times, mark cam chain and not realise the timing is dependent on the position of crank, the marks line up even after it's 'fallen off' crank sprocket so timing has moved ::)
It's always 'interesting' to see 'time saving' shortcuts that cause way more problems than doing it properly
The fact valve adjuster lock nuts fell off should tell you something about mechanical ability?
He's saying it turns over with cam cover off, no rocker arms pushing on valves.
The problem can't be cam chain or it would lock up even with rockers off.
Locking up only happens with rocker cover in place, ergo, valve timing is out and valve is contacting piston. (OP does state this somewhere)
Only way to find out how much damage has been done is strip it down and check
Trying to avoid doing it right (remove engine for strip down) is only compounding the problem.
It's real easy to get in over your head if your not mechanically inclined and have no one to walk you through it
