Cam chain rattle question - CB550
Shooter
Just how much cam chain rattle should one expect on a CB550 with a new adjuster mechanism fitted?
On mine its noticeable and a little more than I expected.
Thought I would ask the question before I have a fiddle with it.
Problem is that I never really rode my bike before I stripped it down but it was noticeable. I also replaced the primary chain.
BEEEEEEEP...
I'll take the "Cam chain" question for $100 please....For which chain on a cb550 should there be zero noise when a new adjuster mechanism is fitted?
Thank you..
I'll take the "Primary chain" question for $200 please....For which chain on a cb550 should there be no more than 1 inch of slack when installed new?...
Thank you...
I"ll take the "DoTheTon" question for $500 please... Which cafe racer forum has admin commonly referred to as: The Virgin NOS Destroyer, The Manx Alloy Tank Destructor or The Dreaded Priate Long-Shlong??
Thank you... ;D
I"ll t
What kind of crack are you smoking Noel?
Cam chain noise on the SOHC4 Honda's is normal. Adjust as per the manual and don't sweat it. There's also clutch rattle and primary chain rattle.
A total lack of noise from your cam chain means its too tight and then you really have problems.
Shooter said:
Thanx Tintin
Must be Loco weed season where Noel lives ?
No... i'm afraid this is normal... crazy is when he talks like a normal person.
BEEEEEEEP...
I'll take the "Druro" question for $500 please....Who is the DTT member who is NOW paying $1000, for a cb450 project?
Thank you..
BEEEEEEEP...
I'll take the "TinTin" question for $1000 please....Who is the DTT member who will regret selling their Alloy Tank only to see a video of another DDT member chopping it up for a cafe seat?
BHAHAHAHA!!!.. LOL!!!...
Mr Alloy Tank Destructor said:
BEEEEEEEP...
Thank you..
BEEEEEEEP...
Dude... Puff Puff Pass... cause what ever it is you are on must be good... damn you are Loco
Hey - I couldn't care less what whoever buys my alloy tank does to it. But then again, I won't sell it to you, so I have a lot less to worry about ;)
I didn't know the 550 had a primary chain, or any other Hondas. Do you mean the drive chain from the front to rear sprockets? A primary chain links the crank to the transmission like in Harleys and Triumphs.
Yep - there's a primary chain (internal) running from the crank to the transmission. It's not a gear drive. All the SOHC4 Honda's are like that, and the chain can produce it's share of noise.
There is a chain on the primary shaft on a CB550 and it is called the..... 'Primary Drive Chain'
Having raced one for 5 yrs,new cam chain,new primary chain,,ctutch plates,etc etc,,read your manual to adjust the cam chain,,buzz's, rattles,weird noises are all part of the 550,,,,cam it,carb it,pipe it!!!! then the fun begins at 11000 rpm ;D
