This bike is an 81 xs400 special. I also posted this in the build section but I dont think anyone is going to read it. Here is the low down. I am having some fuel issues. I went over everything today. The carbs are clean and all parts pass visual inspection. I have good spark, and the plugs look fine. I had a bad miss on the left cylinder. It had spark but wasn't getting fuel. I know this because the plug was cold and dry, The header was about 100 degrees cooler (inferred temp gun) than the right header,I could pull the left plug wire off while it was running and nothing would change, but if I squirted some carb cleaner in the left carb it would pick up and smooth right out. the carb bowl is full of gas but it doesnt seem to be getting into the intake. I pulled the carb again, but I couldn't find any problems. Now when I start it up it seems to be firing on both cylinders, (most of the time) header temps are much closer, but now it wont idle. In the video I start the bike and it climbs up to 4500rpm, when I blip the throttle it climbs but wont go below 4500. When I pull the choke out it goes down to 1200rpm. Can anyone give me any direction on this? Thanks.
http://www.youtube.com/watch?v=0B_36F62G04
