Can't get it in
lonelywolf8588
I need help figuring out how to get my engine back into my 78 GS1000. It was an absolute nightmare getting it out. I had to turn the frame on its side and lift the frame off the engine after much violent shaking. I don't want to do this now with a freshly painted frame and engine. I was hoping not to have to put the head back on until the lower end was back in the frame, would give me more clearance and less weight, but because the studs I cannot do that, it must be assembled outside the frame. Any helpful ideas?
my bike (made in '80) put up a terrible fight when i pulled the motor, and i'm pretty sure it was basically just grime that made it that hard. i'm assuming it's going to go in a lot easier.
yours may be similar?
I don't think I can because the studs are 6" long. There just doesn't seem to be enough room to put the head on in the frame.
Try and look up the manual online and maybe you can see if they talk about or show pics of the head being taken off while the engine is still in the frame.
Not in the service manual. They do an engine teardown on a bench. I spent some time measuring the frame vs the engine and it looks like it may just fit if I let the engine hang between the rails before I bolt the engine to the frame.
