can't get it off
lonelywolf8588
Get your minds out of the gutter. But, seriously. I can't get the axle nut off the front wheel of my bike. It is a '86 Ninja and uses 12mm allen heads on both ends of the axle. Everything is loose and the nut is on so tight I can't even hold the other end and try to spin. Any ideas? It is soaking over night in PB Spray. Maybe a torch?
Tighten up the bottom fork cap (on one side only) then turn the nut / bolt from the other side. You might need a breaker bar.
Shouldn't need to use heat.
