Can't get no Love, or spark from this bike at all.
slipfit33
Hey fellas,
So I bought this bike about 4 months ago, my first bike, which didn't run yet, because the HS Senoir had detached the entire electrical harness, and painted the bike, with like rustoleum or whatever. I cannot get a spark to the plugs at all. I've replaced the plugs, CDI box (used), ignition coil, twice (this one is new from UK), rectifier (used), and recharged the already new battery. The manual says the CDI/rectifier/ignition coil check out okay, and now I'm at a loss. Man! this SUCKS! I can only guess it may be the pick-up coil or alternator, but the resistances on them check out okay too. Could I not be getting a good enough ground? I've re attached the wire harness painstakingly as the electrical diagrams instruct, and the starter motor will turn, but still can't get no love. Story of my life. You gotta help me DOT. any and alll suggestions sorely needed.
Honda CM250, 82'
The coil also needs to ground to the frame. When the PO painted the frame, the coil is not grounded anymore. Attach a ground wire to the metal parts sticking out of the coil and to a known good grounding point.You can also remove paint between coil mounts and frame to clear metal, but for testing, battery negative terminal is best.
The coil has a black/white wire out of it. put the black/white wire with an extension to the battery positive and start her up :)
