Rich Ard said:What the fuck am I supposed to do with this pitchfork Joe
JRK5892 said:Here is the price breakdown on the "$600" job. little more than just a wheel. we had $87 in powder we had to custom order to try and color match and i would say about 10 hours in samples... running a huge oven for just a sample mind you. the final color required 3 coats of powder to pull off and masking between each coat... removed frozen bearins in the swing arm and joint, and reinstalled the ones that where able to be used. we even took off $65 for the amount of time that it took to complete this job as an appoligy to the customer. Through the process i even offered less $ solutions for coating options along the way
total for this job was $380... NOT $600... i also can provide recipt for this
wheel
Rim: $45
Hub: $75
Nipple: .75 each (41)
Spokes: $1.25 each (40)
Spacers: $25 each (2)
Bearing install: $20
Lace: $65
True: $65
Swing arm
Swing arm: $65
swing arm joint: $20
swing arm/joint bearing removal/install: $45
examples of some of the samples we shot for the customer
MJPriceisright said:yes, I ended up paying nearly 600 dollars for one wheel and a swingarm. what am I gonna do? not pay and not get my parts back? I argued non stop with the guy and finally just said fuck it and got my shit back. total joke.
Now to mjprice is right. Looks like the original price quote was for a solid single coat color. Any time we get customers asking for price quotes on parts we use a standard price guide. basically what you are trying to argue is that you were quoted for a single coat color should still have been the same for 3 coats, which obviously requires 3x the powder, 3x taping, 3x oven cures but you want all that for the same as a single one color? That is just absurd.
Also to anyone else that thinks they can be like you and get a quote for coating (example your swing arm) and then send the swing arm in with all the bearing and seals still installed and expect that for free will never happen. Why would a company not charge for an extra hour labor or more removing and installing bearings? No way should you have expected that for free. We tell customers till we are blue in the face that all our quotes are for clean non assembled parts, any extra cleaning that is not normally required or dis assembly/reassembly of parts is extra. I would assume that to be common sense but believe me its not.
smokin87ta said:Rich - your example of using automotive repair as an example couldnt be further off.
There is no way and never will be a way to quote 100% accurate jobs without having them in front of you.
VonYinzer said:Perhaps this thread should be locked down and the issue handled personally (if there is still an issue to handle). Everyone is being civil for the most part but the more outside opinions interjected, the less likely it is to remain that way.![]()
