Can't get the final driven sprocket back on!
66replica
The Wrecking Crew
DTT BOTM WINNER
Ok, trying to put my rear wheel back on and I can't get the stupid thing all the way on. Been pounding with a rubber mallet for about an hour and a half now. Any ideas?
Stop pounding! Break out the parts diagram. Should be no pounding required - should just slip into place and be held there with the big nut and lock washer.
Is that sprocket powdercoated?
It is indeed. I know the chain will wear it off on the teeth but that's cool.
Did you get rid of the powdercoating in the sprocket mounting holes? Did you powdercoat the mounting studs that go into the cush drive bushings?
The sprocket mounting holes should be clean as the wheel was masked and painted. The may some powdercoat at the top of the mounting stud keeping it from dropping though. Hmm...
Also, to clarify, only one of the mounting studs won't seat. The other 3 dropped.
Clean it with a wire wheel, there's no space in the bushing for anything stuck on the stud.
I'll give it a shot. Makes sense. Now let's see if I can get it out, haha.
You can see in the pic that the studs are not seated in sprocket.
They have to fit into recess, the flats stop them turning when nuts are tightened up.
You don't have sprocket backwards do you with 'flat side' towards hub?
No, the sprocket fits into the studs fine. I believe the problem is the powder on the top 1/4" of the studs.
The splined piece of stud should be completely in sprocket.
Use the nuts to pull them in place.
The studs should not be stuck in cush drive rubbers but should slide out with just a 'good' fit
You should bolt them to sprocket and then fit 'drive pins' into hub, flat washer and big circlip
Thanks. I'm going to heat up the hub a bit and try to pull the studs back out to remove that bit of powder so the slide in a bit easier.
Worked for about an hour trying to get it back out of the hub, no luck. So, I scraped any powder I could see off the studs and tried getting it in again. I think I've got it.
One question though: One of the sides seems a bit lower than the others. I measured it about .3mm lower between the sprocket and hub than the others. Will it matter? Here's two photos to try to show it.
Ok, I don't think it's going to cut it.
So, time to get an even bigger hammer and try to get it back out, scrape powder, check for any other reasons it's not seating and get it back in correctly. This has been quite a learning experience.
yeah that's got to be straight, you'll go through a chain in a week with it like that... of course the sprocket would probably wear out just as fast which would solve the problem (when you got a new one)
Make sure you've got some lubricant on those studs so that they wont hang up for the wrong reason.
Yeah, unfortunately I just can't get the damn thing back out. I've been wailing on it for a couple days now, broke many wood studs I was using. I guess I may just have to go to a new rear wheel. I'm at my wit's end on it. Can't get it to go further on and be straight and can't get it to come back out.
