Ouch... in theory that pad should just slide out.
But dirt, sand, rust & other grime builds up & sometimes between the sides of the pad & the walls.
In theory, if you hook it up to a spare MC and pump, the piston should eventually come out w. the pad. of the piston wall is rusted behind the seal ring, it will stick to the sides of the caliper chamber.
In the past I've had to hook up a spare MC and mound the caliper on a vice and use a torch to heat it up real hot, then pumped it. It will eventually uncease.
Chances are your bleeder valve is also rusted on and siezed. It you torch and heat up the caliper, you can also remove the valve then stick a speed bleeder on it.
Its worked that way for me...
Good luck.
