Just tried fitting my new VM34's to my T500 and the left side carb bowl is hitting the ignition case. Anyone else run into this problem? It is the bump in the bowl casting where the dowel for the float is pressed in. I see 3 ways to rectify the problem but I dont like any of them.
1. I could try filing down the bowl casting but I don't know how much I could take off until it goes through into the hole.
2. I could modify the ignition case (mill a chunk out).
3. I could use the original long manifolds which should give me clearance. However all the engine work was done with the intent to use short manifolds.
I would choose option #1 if I was sure that I could remove enough material without causing an issue.
