Carb Issues? Fuel Issues? Spark Issues? Probably All 3
whoisjake
Active Member
First off... brand new to motorcycles... and have a 1970 CL450 Scrambler...
Now that that is out of the way, I'll describe the issue I had...
I had the bike running fine, idling a little high after it warmed up (which I know I could adjust), but it didn't require the choke to start, started on the 2nd or 3rd kick and sounded like it was running fine.
I took her out yesterday and after a mile it started to lose power, making a few backfire sounding noises... and would bog down... it would come back up to normal for a little bit, but then after another minute, it would do the same thing... then it just died at a light. It started back up and I got it home, doing the same thing, every few minutes it would lose power and backfire...
When I got home, I took the plugs out and they were black (both sooty & a little wet)... The gap on the plugs were at least 2mm (the recommended gap is 0.8mm) so I swapped out the plugs. I couldn't get the thing to start, so I went to pull the right plug wire off and the boot fell off. I figured that was my issue, so I cut the end off, and threaded the boot back onto the wire...
Put the wire back on... and now will only start with the choke, but it only runs for 2 seconds... I got it to run for about 30 seconds with the choke on, but it needed throttle and bogged out after 30 seconds, but long enough for me to feel the exhaust and both cylinders appeared to be firing... and it won't start at all with the choke off.
Too many variables... I don't want to take it to a shop just yet, but it took some fiddling to get it to idle the first time around and now it's just not running...
The carbs are still set the way that they were when the bike was running "fine"...
Here's the formula you need to follow to make sure everything is kosher and top notch.
1. Check valve clearances and compression. Do this first because these issues can mimmick carb/ignition issues. Once you know these things are where they should be...
2. Verify engine timing and that your points/condenser/coils/plugs/plug wires are working right and set correctly. It's almost impossible to get carbs dialed in if the ignition isn't up to snuff.
3. Make sure your carbs are clean and jetted correctly. Not sure what kind of intake/exhaust set up you're running, but if it's not stock you'll need to rejet to have things happy. Make sure your float levels are correct as well while you're doing this.
After you do these steps it's just a matter of fine tuning the carbs with the air/pilot screws and doing a full sync on them to have the bike running perfectly. It may seem intimidating if you've never done this kind of stuff before, but none of the systems on these bikes are that complicated and with the right resources (this forum and maybe see if you can find a forum dedicated to the type of bike), and either a Clymer's or Factory Service Manual, you'll be able to do it all yourself and not have to drop the coin to take it to a mechanic who may or may not know what he's doing.
Thanks for the tips! I understand mechanically what you're talking about in each step, but when it comes to motorcycles and *how* to actually accomplish each step, is where my knowledge falls apart.
I do have some guys I trust around town that could look at it, but I want to do as much as I can before I start to lean on them...
I'm going to research each of your steps and see what I can come up with...
Thanks! This is a way better copy than another one I got... the pictures on the other were too blurry...
So update... I was tinkering with it today and tried re-tuning the carbs and thought hey, let me try the electric starter (which I was told from the P.O. that it was weak)... well the fucker drained my battery...
So I charged it again this afternoon and started it up...
Actually ran for a few minutes this time... and I noticed that it sounded different... but in a good way. The engine sounded like it wasn't misfiring, there was no backfire, and it had a nice running rumble to it... didn't sound as noisy as when I got it... I take that it's a good thing.
I haven't actually taken it off the center stand yet, gonna walk the dogs and then try to take her around the block, see if she'll give me any pull...
Arg, here I go, buying a bike to cafe... and I feel obligated for it to run perfectly before I tear her down and put some new parts on her... So anxious!
Ok, so she cooled down and I tried a cold start. She wouldn't start at all without the choke... that's fine, that's normal (for bikes, but not for her, before she was fine starting without the choke)...
Tried kick starting several times, got her to run for a few seconds at a time (while cold)... then what sounds like a stall... About every 5 kicks she does this...
I noticed something while trying to kick start it..
One cylinder the exhaust was warm (cool enough for me to touch)... but the other cylinder header was too hot to touch...
Seems like I didn't get the carbs adjusted properly... While it was running earlier (a few hours ago), there was good pressure coming out of both pipes... even pressure and only a little smoke while I gave her some throttle. That with the wet black nature of the plugs I found earlier, I figure there's a little oil blow by...
Honestly, if someone wants to come by my house and tell me what's wrong, please do, I'll feed you... :)
Fort Worth... there are a few people I can call upon, I just have to figure out how to get the bike up to them... Don't have a truck and obviously it's not wanting to run, kinda hard :)
I'm going to try to coax a few people to come over and see what they think of it... If that doesn't work, i'm going to give up and take her to the shop... I just want to ride, at all costs
So this is an old 450? Either the pilot jets are getting intermittently choked up from flaky junk outta the tank. Or, what I think is probable....the ignition switch contacts are super crusty from almost 40 yrs. of use. It actually passes a fair amount of current for the headlight and ends up arcing, which makes a carbon spot in the contacts that lessens its conductivity. I went through this with my '74 CB450. I thought the battery kept failing 'cause no power was going any where. Eventually I traced it down to the shitty ignition switch one rainy evening. To get the bike running I hot-wired it with my pocket knife as the only tool. Thankfully no cop rolled buy at the time. :-[
I eventually disassembled the old ignition switch to find thick, sooty carbon arcs, corrosion at the terminals and signs of over-heating. No wonder it didn't work.
450's have a sensitivity to weak power to the ignition system anyway. The engines just don't like being out of sync in the ignition or carbs.
While your machine is not running, the battery recovers just a bit, enough to get power through to get it started again.
The it dies. Repeat. Check the round connector plug as well. You gotta pull the tank for that.
Hope that helps.
Nate in PDX
Here's some more analysis... since I'm new and don't have all the right tools, I did things as much as I could by touch/feel...
Pulled the plugs again, tested for spark, I saw a pretty good spark... on both plugs.
I put thumb pressure on the plug holes and gave it a kick, both popped off my thumb pretty easily... feels like there's good compression.
The plugs are slightly oily...
I'm going to check the points and timing... probably give the fuel lines a look as well, make sure it's getting fuel... and then after all that I'll pull the carbs...
Eek..
Fuel -> Air -> Spark...
I've ruled out spark... (sorta) so I checked fuel... well whaddya know... Petcock turned to on, no gas coming into the carbs...
The inside of the tank is pure rust and the petcock... well... let's say that the little diaphram filter I found was torn in half and almost a whole nuts worth of rust came out of it...
Skip the Kreem and buy the POR-15 motorcycle tank kit. Much better - won't peel off ever and the coating material spreads a lot more easily - my opinion anyway. I've used POR-15 twice and love the stuff.
Ordered some POR-15... wish it would be here faster and didn't have to ship ground!
Now to figure out how to repair the petcock... I got it clear of all the debris, but the seals are probably bad and the screen is torn in half...
Most petcocks have rebuild kits available. Here's one for example.
But be sure you need to do this before bothering. Is fuel flowing freely? Is it leaking? If it's functioning properly, don't sweat it. You might install an inline fuel filter in the fuel line to keep crud out of your carbs, especially if the screen or other rudimentary filters in the petcock are torn etc. They're cheap and good insurance. Just keep a spare or two handy in case it gets clogged on the road.
http://cgi.ebay.com/ebaymotors/Honda-CB-CL-450-CB450-CL450-petcock-rebuild-mount-kit_W0QQcmdZViewItemQQ_trkparmsZ72Q3a1205Q7c66Q3a2Q7c65Q3a12Q7c39Q3a1Q7c240Q3a1318Q7c301Q3a1Q7c293Q3a1Q7c294Q3a50QQ_trksidZp3286Q2ec0Q2em14QQhashZitem250398276657QQitemZ250398276657QQptZMotorcyclesQ5fPartsQ5fAccessories
Here's what I did...
There was a little bit of gas in there, half a gallon... I have inline fuel filters before it hits the carbs and they weren't showing any gas in the chamber (even with the petcock to the on or reserve)... so I pulled the lines above the fuel filter, turned the petcock on... nothing... turned to reserve... nothing.
I took the petcock off, drained the tank...
Tore apart the petcock and lots of rust bits were in both the long tube and the reserve part... the bottom screen was torn in half and there was rust bits throughout all the holes. I used some compressed air and got all the passages clean. But with the screen being torn and the rubber rings looking gangly, I figured a new kit wouldn't be that bad.
After clearing it out, I put it back together, put the tank on and it leaked like crazy through the lever... clearly some bad seals were in there and the rust was keeping the pressure low enough... So I figured I'd buy a kit...
I also see on Ebay some NOS OEM petcocks for $59... not a big price jump from the $25 on just the few pieces in the rebuild kit. Might as well have something that flows good...
Funny, I was going to suggest you check the tank/petcock for rust as you were having similar symptoms to mine when I first got it, and that was my problem.
I ended up getting an NOS petcock because the one I had didn't have that little mesh tube thing over the reserve hole. It acts as sort of a "pre-filter" for the reserve inlet. I can send you my old screen and gasket if you haven't already ordered them.
I also used CLR to derustify my tank, although it wasn't that bad. I haven't lined mine yet. Make sure when you line the tank that you figure out some way to keep the little crossover nipples from getting sealed by the stuff.
Is the POR-15 stuff thick enough to seal a pinhole?
I have found that if your bike runs for a couple seconds (5 - 20) and then dies, you usually aren't getting enough fuel to the carbs, either clogged lines or empty tank.
Also be warned, although there may be a little gas sloshing around in the tank, that doesn't mean that there is enough in there for the bike to run. Ask me how I figured that out on the side of a busy highway during rush hour. ;)
I bought a POR-15 motorcycle kit... $45... and a NOS petcock for $43... not terrible price...
Unfortunately I ordered them 2 days ago and it'll still be another 5 days or so before they get here...
Now what to mess with next?
Any good tutorials on that? I know mechanically what valves are, their function, and where they are on the bike... I just don't know how to set the clearance on them...
A few other things that I want to do:
1) Strip it down and replace (bulky lights, fenders, mirrors, etc).
2) Mount the handlebars
3) Clean the carbs
4) Check the points and timing (another one that I have no idea *how* to do it)
5) Get a seat started...
