Carb overflow is...well....OVERFLOWING!
jbeebe
Hey everyone, i've been lurking for a while, and didn't plan on posting until I could start a build thread. Well i've been doing less building and more repairing.
It's an 81 KZ440 with the CV carbs. they overflow out of the drain hole at the bottom of the bowl all the time. Here's what i'v done:
new valves (along with a full rebuild kit)
polished the brass valve seats beautifully so they aren't getting hung up
adjusted the float height. I set the fuel level lower than it should be, just to hopefully stop the overflow, but it didn't stop.
replaced drain screw o-rings.
checked the overflow tube in the bowl for cracks or leaks, it's all good.
the floats don't absorb any water, they are in good shape
So what the heck is jammin' me up over here in Cleveland!?!?
I'll reward the first reply with some pics of the bike. ;)
Hey! Welcome. Are you sure you adjusted the floats lower? Ive seen a few people adjust them the wrong way. It can be confusing. I dont know if this is your first time working on carbs or not.
Like if you bend the tab on the float upwards (doing this by memory, so dont hold me to it), you are lowering the float and vice versa. Might wana double check that since it seems you have everything else sorted.
With the carbs upside-down, i bent the tang down, or in towards the valve to lower the fuel level. Once i put the carbs back in today, the fuel level was really low (~8mm below the mating surface, it should only be 3mm) so I bent the tang back "up" away from the valve a bit, thinking that the lower fuel level didn't help anyway. I have the FSM for it, but the wordage is still confusing sometimes, so correct me if i'm doing it wrong.
as promised:
it's nothing to look at now, only did repairs/maintenance and a little cosmetics. I want to sort out all the repairs before I start really mod'ing it into a budget brat-ish thing.
from day one to how it is now:
Hmm...it sure sounds like you did it properly. You replaced the float needle you said? And is just one carb overflowing or both?
Both, but one leaks more than the other. Yup, new float needles with fresh and supple rubber tips, ready for the plugging.
I'm checking the float height the following way:
with the engine off and the petcock open, i open the drain screw and view the gas level through a clear tube alongside the carb while holding the bike up off the kick stand. Does the bike have to be cold for this, or doesn't it matter?
My KZ550 had the ol' honda cb900/1000 Custom problem...which might plague you as well. Make sure that your brass overflow tube doesn't have a hairline crack in it. I polished the float valves, got new needles , changed float heights and it STILL leaked gas. I found the crack, and soldered it up, no more leak! Might be your issue too.
i pulled the bowls off the carb and filled them with water, no drip. So i'm guessing that there shouldn't be any cracks in the tube. right?
... Make sure that your brass overflow tube doesn't have a hairline crack in it. ... I found the crack, and soldered it up, no more leak! Might be your issue too.
+1 ...
Those "hairline cracks" are sometimes thinner than a hair.
A quick fix for this is to put a snug tube/sleeve over the stand pipe.
And water is a different viscosity and may not leak where fuel might...
+1 to check for hairline cracks.
I had the same problem. I found the easiest solution, apart from putting a tight sleeve over was to solder the crack up. Spent ages trying to diagnose the problem, and then 10 mins to fix it....isn't that always the way!
To help isolate the issue, try taking the float bowl off and filling it with gas. If it leaks, there is a crack somewhere or the drain screw is not seating correctly (if your bowl is designed like this). If its fine, try keeping the bowl off and checking the float needle. Gently push the float up and turn on the petcock to see if its sealing correctly. Can get a bit messy but it allows you to see if its working correctly. If that's fine, the float may be getting hung up on the gasket or is not moving freely on the pivot.
It's as if you guys tap into my stupidity. After doing the water in the bowl to check for leaks I guess i never really inspected the tubes for cracks thorough enough. So after doing alllll that work trying to diagnose the problem, i spent a couple minutes cleaning the buildup off the tubes and BEHOLD:
So soldering them up is the best solution, got it. I suppose JB-Weld would work as well? Anyone have a technique for soldering them, I haven't really done much soldering besides wire connections, never anything little and fine like this. Like, do i use flux? should i use a pencil soldering iron, or just a propane torch and solder? what type of solder should i use?
Thanks guys!
Is JB weld petrol/gas resistant? I'm not too sure it is...solder would be your best bet.
I used a pencil soldering iron, with pre-fluxed solder. Was a bit fiddly to make sure the crack is completely covered on the outside and not blocked, but it only took about 10 minutes to do.
NO to JB weld.
VERY simple. Make sure you have flux, even the stuff used on copper pipe in your house (if you have ever had to fix plumbing) will work. Get it good and hot with the solder gun before you put any solder on it. Then quickly get solder on the gun and go back to it (keep as much heat as possible on it) and it should flow really easily to the whole length of the crack.
Good luck, it's worked every time for me, but that's a pretty large crack, make sure you get enough solder on it!
NO to JB weld.
Sounds good. I'll do it this afternoon and post my results.
So I apply the solder right off the tip of the gun? versus just heating the tube with the tip and touching the solder wire right onto the crack.
Ok guys, I just soldered up the cracks and tested the bowls for leaks, it's all good. Thanks for your help. I had some trouble getting the tube hot enough with just my 25W pencil iron, so i torched the tube, put some solder on the tip of the gun and laid it on. It's sloppy ( a manifest of my soldering inexperience) but it works.
All ready to go back in tomorrow morning....
