Chisel any remaining tube level with the aluminum.
Drill it out with a #25 drill bit.
Get a length of 5/32 OD brass tube. (Available from hobby shops and some hardware stores.) Make it 1/2" or so longer than needed. Heat the tip with a torch to anneal. Peen the tip to a smaller opening.
cut to the required length, and press into the hole you drilled out.
