Carb pissing fuel. Stuck float?
Fear My Twin
Chicks hate my bike.
She was running like a top yesterday and then I go to play with her and the left carb is pissing premium fuel all over my chain cover.
Im guessing its just a stuck float.
How does a float get stuck? What should I look for while my carb is open?
Thanks guys!
Could be a hole in the float or the float valve is leaking or the float height is too high. All these conditions would lead to the float overfilling with fuel and leaking out the overflow spout. Or maybe the float gasket is bad.
I had some debris get into the bowl from the tank... and got wedged into the float pivot... did the same thing. ALWAYS check your bung hole tape when sanding bondo ::)
Pulled the bowl, shot it all with some cleaner, wiggled things around, shot it again, reassembled and off I went.
They'll move up & down with the lightest touch of your finger... if they don't then you have more of a problem.
Fear My Twin said:
So as long as I dont mess with this little arm I wont risk messing up my float level right?
Sorry, im such a noob.
That metal tang is what determines the float height. You need the float height spec from the manual and bend that tang until the float height is correct.
