downeaster
Hey all, Im having a carb issue and was hoping some one could point me in the right direction. I have a 8 valve GS 750, stock exhaust and airbox with a KN filter. The valves are all within spec's on the loose side. Last fall I put new intake boots and o-rings. I just got a o-ring kit for the carbs and am planning on taking them off and dipping them next weekend. When I start it cold it wont stay running on the choke. I have to use it to get it to fire up but the it dies. then it will start but not with the choke, I have to keep it going with the throttle until its warm. when I was adjusting the air screws, seating them and turning them out to the highest idle the number one carb doesn't change anything. that exhaust pipe is slower to get hot also. I checked and the tip is not broken off the screw. All the fuel screws on the bottom are turned out 7/8 of a turn ( I read that that's a good starting point, but I really don't know). What should I be looking for when I get them off? I Know obviously something must be plugged. Any advise would be greatly appreciated. thanks
