carb rebuild/ cleaning question
sbaugz
DTT BOTM winner
So, I recently started to tackle rebuilding my Keihin CB360 carbs. I took them completely apart and have a K&L rebuild kit waiting to use.
I searched around and decided to go with the lemon juice cleaning technique that i have read about here. I boiled the carb parts in lemon juice for about 20 minutes. All the crud, sludge, and oil came off nicely. I then proceeded to use a scrub brush in warm soapy water to get any stubborn stuff off and to wash lemon juice off. Finally, I sprayed them liberally with carb spray to get rid of the moisture.
The problem is now that they are dry, there is a dusty film covering the entire carb bodies, and this film is like stuck on the carb. Its like a caked on powder that covers the entire carb. I used a wire wheel and got alot of it off, but there is still this coating in all the little spaces and crevices and in all the threads of the carb body. Any advice? I was tempted to just re-assemble carbs, but I don't want this dusty stuff to gradually come off and plug up the needles. I tried spraying the crap out of them with carb cleaner and it won't come off without some sort of abrasive or wire brushing to it. I just can't get into all the crevices to remove it all. I thought about soaking in gas but not sure that will do anything.
THanks
http://www.amazon.com/B-9-PARTS-CLEANER-BASKET-GALLON/dp/B0002KKIIC/ref=sr_1_5?ie=UTF8&qid=1326042255&sr=8-5
i used this when cleaning my carbs and it worked like a charm, i used it for only metal parts and i always let them soak in it for 24 hours then rinse with hot water to help evaporate quicker and then sprayed and scrubbed with simple green to make it shine, then rinsed again.... you should give it a try
Thanks, might check that out.
I guess my point was that I feel like they are clean already. THere isn't any sludge or oil on them- its simply this residue of some kind. Not sure a carb soak will work since I already doused it with spray carb cleaner and this powdery film didn't come off then.
Use the DIY soda blaster to get them 'pretty'
Lemon juice boil etches the surface, you could probably do it over and 'anodise' them?
Just look up how to seal anodising
DIY soda blaster as above, or see if you can get your hands on an ultrasonic cleaner. ;)
first of all. dont blast carbs. blasting removes material, carbs are precicion-engineered. Second reason is you'll never be albe to clean all the blasting material you used resulting in clogged carbs or worse.
ultrasonic is the best (and most expensive) way to do it.
my 2c...
i cleaned my carbs once using the lemonjuice, didn't get the film youre talking bout though..
I'm no anodizing king , but this is to my best knowledge how it goes:
Lemon juice is acid and open's the surface pories (dont know usa word) in the metal. the surface pories are then open and when you take em out the lemon juice and clean with CLEAN boling water (no soap/carb clean) the pories retract, sealing the surface. Anodizing works the same in theory. Open the pories with acid and seal em with coloured hot water.
Water can be coloured with food-colors or ecoline.
The mistake you made (i guess) is using soap and cleaner. It went straight in the pories and that's what giving you a pita cause it's now part of the material.
I'd say boil em again with lemon juice and clean em with CLEAN water. Prior to doing anything a stated, read this:
http://astro.neutral.org/anodise.shtml
good luck!
so I boiled them again in lemon juice, then dipped in water/ baking soda mixture to neutralize acid (this was recommended by someone on the honda twins forum). Then I rinsed with water. Dried them out with my air gun. Guess what- now the carbs are coated with a white powdery substance very similar in appearance to baking soda. This time around, I used a wire brush and wheel, soaked them in gas, and was able to get the white stuff off. I think I am ready to rebuild them now. I only hope the rebuild goes easier than the cleaning process did.
Soda blasting is very gentle and can be washed off with water, it isn't the same as 'solid' blast media (glass, grit, walnut, etc)
Jan, PORES, you English is way better than my Flemish/Dutch (I have enough problems with 'American' English and still can't speak any 'European' languages ;D )
Main problem, in Britain, they teach for exams rather than daily use ::)
