Carb ?'s
Hot Rod Troy
Coast to Coast
I need help finding a cross reference chart for honda motorcycles. I have an XL350 'Thumper' and need a carb for it. Does it matter what the carb is from as long as it fits the manifold? It had a Keihin 075A or PD01A with either a 36 or 38mm opening. I am still trying to figure out weather it's a '76 or '77. VIN tag says '76 SN: says '77.
Any help would be appreciated.
Thanks,
Troy
VIN is correct, it's stamped at factory..
could have been flosating around on a boat for a few months then stiuck in docks and dealers for a few more.
You ain't got a 36 or 38mm carb on an XL350, maybe a 26~28mm. (your measuring airbox side opening, not the actual carb size)
Honda were very conservative on carb size for a playbike.
You'll only need a 32mm roundslide on it at maximum, anything bigger and it looses all bottom end
Its a lot easier to find carb for a fourstoke that will work rather than fit a carb from a two stroke that will need lots of jetting (and probably be too big)
Your probably on your own if you fit a roundslide Mikuni.
I would be very wary of anyone saying they have them with correct jetting (unless they actually modified and rode one in 76~77 and can verify it)
PJ
