carb theory...
rockcitycafe
I make things.
can I get a tiny little bit better power from an otherwise stock cb750 engine by removing the chokes from the carbs and plugging the shaft holes?
yes. if you fill the holes with jb weld or regular weld and then file it perfectly flat the carb will flow a bit better.
how much power more power? not enough to make losing your choke a reasonable option... just imagine starting the bike in the cold!
but either way, i say go for it. if you know what your doing you can start a cold bike without the choke. plus not having all those levers and stuff is nice ;)
in theory that may work...but how much extra HP would you get??.. I have no idea...
Then questions would be, how the hell you start the bike cold???..
My cb750f ALWAYS needed the choke on to start in the morning...
Instead, why not grind out the outlet ridges?
I think they talk about this on Batemans Racing or Group W racing .com. More of smoothing out the intake port I think
Just don't let the engine get cold! Right?
HAHAHA.. yeah!!... just keep it running 24/7 and never turn it off.....just make sure you put a fan to it when you goto bed at night!!.. ;D
pick up 4 stroke performance tuning in theory and practice by A. Graham Bell... loads of info in there, and doing exactly this is mentioned and gone into detail in the carb section.
If im not mistaken, a pdf version is floating around the web... i had that, but the book is great enough that i decided to purchase a copy.
I think the trick to starting the 750k with the 77-78 carbs is to pump the throttle a couple times, that squirts gas directly into the port through the accelerator pump, when I had my 78 I rarely used the choke even in Rochester
unless your racing there really isnt any point in doing the mod.
pre77 didn't have accelerator pump, they fitted it (along with air cut valve) to compensate for leaner jetting
PJ
