Carburator Question: Jet Needle Removal.
whistler211
Hey all, long time reader, first time poster.
I recently made a purchase of a 1976 cb360 that I am going to be rebuilding/turning into a cafe' bike. I am in the process of tearing into the carb (my first such experience) and I have a question not covered in the shop manual.
I've taken the top/diaphragm cover off, and removed the needle jet screw in hopes of getting to the jet needle. The manual seems to act like this should allow the jet needle to come out, however it isn't. As part of the rebuild I also took off the float valve cover and have removed jets to replace them. In doing so I revealed the bottom or "tip" of the jet needle. I tried pushing on this lightly but no more for fear of damaging it. So my question is, what do I need to do to get this bugger out? Do I have to remove the vacuum piston and if so, how do I get it out.
The problem could very well be that it is simply a bit stuck and I am not using enough pressure to get it out. Thanks for reading, I appreciate your time.
Here's a microfiche view of the carb, just so you can see what you're dealing with...
http://www.friendlyyamaha.com/fiche_section_detail.asp?section=121572&category=MOTORCYCLES&make=HONDA&year=1976&fveh=2909
If you look to the upper right, you'll need to remove #7 (the lower one. not sure why there are two different items labeled #7). The diaphram and piston should come out as one. You mentioned that you already removed the cover. I'm guessing the spring also? You should be able to slip your finger into the carb throat and gently push up on the piston. Once it's out you can put a little more pressure on the needle by lifting by the shaft instead of the tip, and it should slide out. Generally the spring is what holds the needle to the bottom of the piston.
The rubber diaphram will probably be stuck to the carb body, so gently peel it off from the outer edges. Be careful not to tear it (IE - dont try and push the slide out of the carb before you free up the diaphram). There should be a recess in the carb body where the diaphram sits in - and the diapram might have a bulge / lip to locate it in a certain position. Take note of this if it exists because you'll need to re-install it in the same place.
Check for cracks / tears in the diaphrams while they are out. If they have any holes, you need to replace them or else you will never get your carbs tuned properly.
Hey guys,
Thanks for the responses... and yeah ktree, that would be nice, unfortunately I am dealing with a budget, but that would be a nice and easy upgrade later on.
Hillsy: I had already removed the diaphragm carefully and checked it for tears, those look good so thats good news. Thanks for the tip.
Redbird: I 100% followed everything that you said, however my problem is that the vacuum piston is not wanting to budge when pushing through the carb throat. I even tried a bit of careful prying to no avail. Perhaps I should just try harder.
Again, thank you for the responses :D
It's probably gummed in.
Turn diaphragm up and carefully spray some carb cleaner around top of slide.
Spray some through throttle bore as well (open butterfly)
Should free up in about 10~15 mins
Awesome,
I will try that first thing tomorrow. Thanks again for all of your help fellas, I hope to get this thing a couple stages in then start a thread perhaps... all of the help is highly appreciated.
Cheers,
Josh
PB Blaster works pretty good too.
EDIT: Wait, might wanna stick with the carb cleaner. Not sure how/if the PB Blaster will affect the rubber diaphrams.
I used PBB, but I don't have CV carbs ;)
Update:
Looks like the carb cleaner worked wonders. I was able to spray a bit around the top of the piston without getting any on the diaphragm, and after a bit of prying, was able to get it off, on both carbs YAY!
My next question, with the full tom/bottom end off of the carb, is there any reason why I cant just soak the whole damn thing in carb cleaner, then boil it in water, or something to that extent?
Yamaha makes a really good carb soak solution also. I've ised it on several occasions with great success.
With either product, as ktree stated, no plastic or rubber goes in. It'll eat them up. After soaking just blow them out with compressed air, and reassemble ;)
