carburetor problem
c.stikeleather
motorcycles and surfing
ok so i a 1969 honda ca160 and my carburetor keeps leaking gas and also has a vacuum leak. i have cleaned out my carb, bought new gaskets, new float, and new float needle. i measured the float to what was recommended which is 19.5 mm and took my time with putting everything back together. when i fire it the rpm's go way up and it sounds like im just holding down the throttle, then it will start to let gas out of the brass nipple and wont stop until ALL of the gas from the tank is gone. i though the needle was far enough down but do you think instead of a vacuum leak it could be something wrong with the needle like letting in to much gas??? dont know, ive done alot of research and im at a lost! please help!!!
thanks,
Cody
Pull the bowl and see if the overflow tube is cracked. If you're float hight is correct then this may be the issue. Even with new gaskets if the carb handler (black rubber manifold) is to brittle it will never seal properly.
