Carburetor puking
JMazier
Active Member
Hey all,
I have a CB350F and lately in the morning when I go out to the bike to start her up there is a small puddle of gas under it. No leaks from the carbs so I am guessing that it comes from one of the overflows
The weird thing is that it only does this overnight. When I drive to work I leave the bike parked for 4 hours in the morning...a quick ride at lunch and parked again for 4 hours in the afternoon. During these periods no gas comes out. I then ride home and park it for the evening. I have checked in on it after 5 hours in the evening and still no leak however the next morning, after being parked overnight, it has leaked. What gives? Andy thoughts?
I would guess one of your float needles is sticking, I would clean them for fun. Not sure why it does this overnight. Are you parked on some odd incline to make gravity work in mysterius ways?
Harry
OK...so I took apart the offending carb and found a surprise...the PO had broken off one of the arms that the float pivots on and decided to glue in back together with what looks like fiberglass resin. The resin turned to mush in the gasoline, the pivot arm shifted and the float was binding. The good news is that theother three carbs are fine and all of them are sparkling clean. So now to get the pivot arm properly welded.
Thanks!
hamfast said:
Coool.
I have used a jb weld before if you let it cure, it will work very well.
Cheers
Thanks! That is exactly what I am doing however I am drilling a small hole in both pieces to put in a piece of wire between then as "rebar". Should be nice and strong.
Cheers!
Cheers!
It is done and working fine. I actually got Robert at Pannon Sports to fix it for me (I took him the carbs). Glad to have the bike back.
I do have another question, how much smoke coming out of the ventilation tube from the cam/valve area is normal. After a run I seem to have quite a bit of oily smoke coming out of that pipe? I am accustomed to modern engines where that smoke is pumped back into the air intake so you don't see it. How much is normal???
