Carby overflow hoses
loudest143
Insert sense of humor here---->
Dumb question of the week! Yay!
So switched over to pod filters to get rid of that pain in the azz airbox. I've got two overflow hoses that come out of the carbs. They are designed to route excess fuel to below the motor, if something bad happens. (don't really know exactly what they do, since I've only had gas come out of them when I left my petcock in prime too long)
Here's my stupid question of the week!
I plan on keeping them, but was wondering if there is any reason I can't combine them with a Y coupler. I plan on adding a Y coupler and another section of hose to get these things routed out to an area that won't be an issue if there IS some overflow.
Thoughts? Amusing anecdotes? Flames?
loudest143
go ahead t's not a problem. Keep length about same as present or even slightly longer. Dont remove them as pulses in float bowl can cause condensation to form in float chamber (Yamaha had some issues when they shortened overflow hoses)
why was it dumping fuel when you left the prime on for too long,,,,,,check your tank for crud....install a fuel filter(s),,,,,check your float valve(s)....there old carbs and periodically :o jam up and piss fuel,,short overflows will dump fuel all over frame,,a long one will dump it on the ground,,,,the same place your your battery overflow should be...
T's are ok, just make sure that they aren't resting against the motor or else over time they could melt. And try to keep the parallel to the ground and then run them down. Don't know of any problems with this, just thinking if the gas NEEDS to come out, make it easy for it to do so
the only reason i can think of to say no, would be figuring out which carb the gas came from... i used a brass "y" over the "t".
