case reassembly
rentedshoes
I am sure the answer is here some where but it is likely much faster just to ask. I split the cases on my cb175 and am ready to put them back together. Is there a sealant or compound that is used to seal the halves as there was no gasket?
Clean both mating faces with rag and acetone or isopropyl alcohol and smear a thin layer of Three bond on one surface. Lay all the parts in and try not to touch the surface while you do that and then put the other half on.
