CB 175 fork seal install question
rentedshoes
Gentlemen,
I am in the process of installing new for seals on my 72 cb175. I got it apart just fine. The problem is installing the new seals. I am having trouble preloading the leg & trying to press the seal evenly into the lower at the same time. Any tips/tricks? I assume there is a specialty tool for this. Help!
Side note: I did consult the service manual I downloaded and it said to "push in the oil seal" no mention of the process.
Im not sure what you mean by 'pre load' but I did my 550 seals recently. I had the best luck laying the keeper ring on top of the seal and hamering on it -carefully gouging the seal is bad. I worked my way around and around pounding it in a little at a time. If you have some thing more blunt than a screwdriver that would be safer. I think I had my allen screw threaded in the bottom to keep the spring tension from being an issue or I may have had the top caps off still and put them on later.
I applied a little oil on the seal the other night when I was working on this. In bicycles, you press thing together straight and evenly. Guess I may give that a try. It is a little concerning that nobody else had any issues. Back out to the garage!
