herre
Hi,
Recently my cb200 cylinder head gaskets started to leak. Figured it was time for a complete revision (after 25000 km). So I took the entire engine apart, changed all the worn parts and put it back together. I also changed the carbs to some cheap but ok 20mm ones. The stock 18mm carbs were all rusted up. Last weekend I got it running. It actually started quite good and fast. But its revving up way too much.
Here's what I did:
-Changed jetting on the carbs to 98/35
-Air screw 1,5 turns out, Slow run 3 turns out
-Gas needle on stock setting (clip in the middle)
-Put the carbs on (not synchronized yet...)
Here's the video of the first start:
http://www.youtube.com/watch?v=hXnLsYrSeiU
How do I continue? Why is it revving up like that? Too much fuel?
Oh and one more question: I put in 15w40 semi synthetic as for now. I'll change the oil when the carbs are tuned. Newly rebuilt engine needs a "flush" anyway right? But what oil should I use? Is mineral oil better for old engines? Can semi synth harm the engine?
Any help is appreciated!
Here's what I did:
