CB 350 Electrical Help!!
Denver_CB350
New to the forum and I just want to say thanks for any help in advance!
I have a 71 cb 350 that I have been working on for the last couple of months and everything was going great. However, about 2 weeks ago the electrical started getting crazy on me. It started with my taillight, it kept blowing the running filament as soon as I would get the bike going. Then my blinkers stopped working, the right blinker turns on and stays on, as in no blink just a solid light and the left does nothing. Next it decided that using my rear brake should cut all power from the bike, so I tried disconnecting the brake from the brake light and that was fine for a day or two and now finally anything electric kills the bike and the starter stopped working. I can still kick start the bike and take it out but it has started misfiring on both cylinders since the electrical issues have progressed.
I'm kind of stumped and I don't know much about electrical so I thought I would see if anyone has run into this before?
Thanks again everyone.
That's a lot of electrical problems. I think your best bet would be to unhook everything and start over. Try one circuit at a time and every time you plug something new into the harness, test everything you've already connected. So start with the ignition switch and the headlight. Test those things. If it works, add the tail light and then test both the headlight and tail light. Next add brakes and test headlight, tail light and brakes, etc, etc, etc.
