CB 350F Getting there...slowly !!
Got a cpl pieces in today.
I may try to move it to this new location. ..any reason I shouldnt?
Think I can get these to seal without leaking fuel ??
  • 6mm-25pcs-Flat-stainless-steel-Rivet-Nut-Rivnut-Insert-Nutsert-blind-nut-fastener-.jpg
I think if you tig welded the circumference then it would seal up but I would bet that anything else will eventually leak.....but thats just my 2 cents worth
Anyone know the difference between these mounts??
Got some rod ends in today. Threaded some rod and done!!
Tore the caliper apart and painted, but I need a piston and seal for it.
Great thread.. and project. Rear Sets look great. I've just rebuilt my front caliper on the CB400f if you want an image of the bracket!
Do you plan to run electronic ignition.. something I've been thinking about.
David Silver in the UK do one... https://www.davidsilverspares.co.uk/CB400F-SUPER-SPORT-FOUR/part_308811/ Looks ok to me!
Little before and after on my caliper hanger
Played with some spray bombs today. Gold base with red top coat.
Looking good, couple of questions - what was the process used to get that hanger so shiny?
Also front fender.. I've just cut mine down and started to play around.. but its on a standard bracket and fits really high.. I wondered what positions yours fitted as maybe I can use a 350 bracket???
