CB 350F input?
Hoosier Daddy
Earache my eye...
First official question for the forum. This bike is really what brought me here. When I searched "cafe CB350F" you guys popped up. A guy on another forum I am a member of wants a GL and I have an old parts bike that he is interested in. In an effort to be fair to both of us what kind of value would you put on this so I know what to put on the tradeing table.
'74 CB350 Four runner but only when kicked. Starter may be toast or not.... and as a note, electrics don't scare me at all.
Re: CB 350F value?
I was given a non-running one about 18months ago, all there and turns over, just havent had time or inclination to get it running
PJ
Re: CB 350F value?
I paid $300 for a 1973 CB350F back in 93. Starter didn't work on it either. Took it off, bike started fine with the kicker. And the 5 pound weight reduction is equivalent to 1/2 horsepower gained.
I know the last one we sold at the last shop I was with went for $1295, but it was cherry other than a mismatched headlight and side panel.
Running CB for a "Lead Wing" parts bike sounds about right. See if he'll go straight across.
Re: CB 350F value?
This is looking more and more like a reality...
He and I been PMing back and forth. He addded this
"On my 350 the picture shows the most of it. All the chrome is good, fuel tank wasn't even rusted when I cleaned out the fuel system. Rear hub polished, along with slide caps, and float bowls. New Tires and tubes, title clean as a whistle. Hasn't been run in about 18 months but it is inside stored and fuel was treated. Will need a battery. I would check the fuel system again and fire it up to double check everything."
Problem is, I been reading up on the 350-fours and it sounds like they aren't that great of a choice, more like an uneducated buyers sucker punch. Handle like shit... Rods going through the block... parts made of unobtainium... Do those bikes really have that bad of a rep?
Next addition from the current owner...
Now as for the cb. One thing I forgot is the starter button stopped working, corroded contact I suspect. Pulled all the plugs and shot some mystery oil in the cylinders, checked the gas and poured some sea foam in for good measure, turned the motor over a few times, add three pounds of sweat (kick start) and we have heat in the headers! I have only put about 300 miles on this bike in 4 years. I don't think the nubs are worn off the tires. This was the first time I have pulled the plugs since I first got it running and they were pretty sooted up. It's either running really rich, or the head gaskets on the way out? I suspect the latter.
Suspect a good tune-up, maybe carb work is in order before blaming the head gskt... Seems to be a few items on e-bay, some NOS... looking better. ;D
Dont know much about the 350 fours, but IMO it makes more sense to go with a twin. Just as an example:
Twin specs:
Model: Honda CB 350
Year: 1972
Category: Classic
Rating: 74.9 out of 100. Show full rating and compare with other bikes
Safety: See our safety campaign with the high safety rated bikes in this category.
Engine and transmission
Displacement: 325.00 ccm (19.83 cubic inches)
Engine type: Twin
Stroke: 4
Power: 36.00 HP (26.3 kW)) @ 10500 RPM
Compression: 9.5:1
Bore x stroke: 64.0 x 50.6 mm (2.5 x 2.0 inches)
Valves per cylinder: 2
Fuel control: OHC
Cooling system: Air
Gearbox: 5-speed
Transmission type
final drive: Chain
Physical measures
Weight incl. oil, gas, etc: 170.0 kg (374.8 pounds)
Chassis and dimensions
Front tyre dimensions: 3.00-18
Rear tyre dimensions: 3.50-18
Front brakes: Expanding brake
Rear brakes: Expanding brake
Speed and acceleration
Top speed: 165.0 km/h (102.5 mph)
Other specifications
Fuel capacity: 10.00 litres (2.64 gallons)
Four specs:
General information
Model: Honda CB 350 F
Year: 1973
Category: Classic
Rating: 75.2 out of 100. Show full rating and compare with other bikes
Displacement: 347.00 ccm (21.17 cubic inches)
Engine type: In-line four
Stroke: 4
Power: 34.00 HP (24.8 kW)) @ 9200 RPM
Compression: 9.3:1
Bore x stroke: 47.0 x 50.0 mm (1.9 x 2.0 inches)
Fuel control: OHC
Cooling system: Air
Gearbox: 5-speed
Transmission type
final drive: Chain
Physical measures
Weight incl. oil, gas, etc: 178.0 kg (392.4 pounds)
Front brakes: Single disc
Top speed: 159.0 km/h (98.8 mph)
Fuel capacity: 12.00 litres (3.17 gallons)
Its heavier, slower, and you have the joy of 2 more of everything engine wise... Not a bad bike, but you could probobly find something better. Be it a Honda twin or something else.
Looks like the specs I had found on Bikez.com, great sight for researching unknown models. And yea you are right on the HP : weight ratio... wonder why it got slightly higher rating... maybe the 4 cyl pissed of hornet exhaust tone!
If this deal does go through, maybe I'll just clean her up and flip it ... use it for a stepping stone to a CB500 or 750 that needs cafe-nated after the GL gets old on me.
Funny how the rating for the 350F is higher than the twin, even though it has less power and more weight ::)
Spec sheets can be misleading - don't judge the merits of a bike by them alone ;)
350F was my first bike. It's fun as hell to ride. It supposedly was Soichiro's Favorite bike. The head gasket is a known problem. They seep. It's more like an early mini touring bike. The 400F is the real "little pissed off hornet", but I would jump at trading a non running heavy ass gold wing for one. They have better style in my eyes.
If your non married to the idea of "restoring" it, you can make a good deal from the "parts made of unobtainium" hahaha!
Never heard of the rods through the block thing... Maybe it's a fluke?
BCB
This is what it looks like (CB350f, spare engine)
Doesn't usually go through block, the case is thinner :o
PJ
Who came up with 36 HP for a stock cb 350 twin :o the in, was 28 hp dyno at the crank(honda's claim and the early engine) as for the top speed the latest edtion of ,,,,,,,umm retro classic???????( I can clarify) shows a tricked bonniville cb 350 salt flyer posting a speed of a 107 mph...and yes you have to consider a HUGE elevation difference,,,food for thought :D your cb cb350F will bolt on to a cb400f bottom end.....looking at your purchase it might be cheaper to purchase SS fasteners than replating :-\ I won't worry about punching out cases unless you ride it like an arse.if you want to totally BEAT(8500-9000rpm) a honda,,purchase a cb 500/550 ;D
With very few mods a CB550 will spin to 13,500 rpm. ;D
I've got one of those as well, done about 106,000miles
PJ
Deal is set for the 27th. We are meeting half way between our two towns... I have been totally honest with the guy on all that is wrong / missing off my parts donor bike and he still wants to go through with it. He said early on that the CB350f was a "freebie", so I guess he's thinking he's got nothing to loose to get a bike he really wants. Here is my tradeing stock. '81 GL1100 Aspencade engine seized no starter, headlight, taillight, seat, title, gauges are busted up, and the list goes on....
6 days and counting! Been doing some searching and getting ideas, found www.SOHC4.net. Not bad but definately no DTT!
Also found this cb350f a guy bought on E-bay.... I will do it a little different, shorter tank with longer seat... but Ohhhh they got potential!
All is ready, got a spot cleaned out in the garage I can squeeze the new bike into. Trailer is loaded and cell phone charging, snowing and drifting like crazy, should make for an exciting 150 mile adventure in the AM! I am really stoked about getting the lil' sis to my GL1100, this CB350f should be a fun "around town" bike once she is done in a cafe' sort of way... but I'm starting to wonder if I will regret getting rid of my donor bike before my Bobber Goldwing build is done.... nah, there is always more out there if needed. ;D
Wish me luck!
Done deal... Here is the linky to an eventually very loooong build thead.
http://dotheton.com/index.php?topic=13778
Gonna call her "Lil Sister".
