cb 360 cylinder gasket
ryzeabve
75 CB360T
Noticed that my 360 is leaking oil onto the fins of the cylinder.. it seems to be coming from the cylinder gasket below the plugs... I read some posts about the breather tube being pinched and causing leaks in trouble areas so i repositioned it to make sure all is clear.. Now if I were to replace this gasket, would I need to pull the engine or am I lucky enough to be able to reach everything without doing so?
Any advice on the issue would be welcomed..
Thanks..
You can change head gasket without removing engine.
I probably have a new one on shelf as I build 378cc motors and can't use stock gasket
PJ
The hardest part is getting that cam cover back on. I've done this rebuild several times with engine still in bike.
I have taken the top end cam cover off so its good to hear some feel that is the most challenging part.. So do I just get that top end off and then work my way down to be able to split the head and replace the gasket?
I think I misread dirtbag's post.
Got another long day today, working double shifts :(
Be home after midnight
Re-fitting cam cover is probably he most difficult part but it's not 'difficult'
Make sure you have rocker arms held up when you re-fit so they don't catch on valve tips (you did remove inspection caps?)
I back off adjusters as tappets will need re-setting
thanks for the advice and manual link... i have a clymer but this one def fills in where the clymer doesn't... should be able to get it done with the help given..
