motormayhem
Active Member
Hey guys,
My CB 360 as been running ok since I got it running after a 10+ year storage, but always had kind of a dead zone in the 2-3k rpm range where it seems like it is running with the choke on and then once it is past that it takes off. I pulled the carbs to check float height and everything. Both carb floats were set a little too low (overfilling bowls) so I raised both to .75in.
When I put the carbs back on the bike it ran great on one cylinder and the other would idle alright, but cuts out around 2k only lights back up around above 3k if your in the 30-70% throttle range. If I pull the plug on this cylinder and try to rev the bike on the working cylinder it revs up and down no problem, but if I pull the plug on the working cylinder this cylinder will only run the bike with a light amount of throttle and if you open it up it blows black smoke, rpm drops out to about 1200, and it will stall after about 30 sec or if you let off the throttle too fast. Since i've been doing this mostly with the air filters off I did notice this carb also has some gas mist coming out of it when it is chugging at full throttle and if you put your hand in front of the intake to that carb it will get wet with gas. Any ideas?
