Hello, this is my first post on DoTheTon; recently I got CB450 in perfect shape. She was a sleep for 7 years; after I put new oil, sparks, and battery and cleaned a tank she started up without any problems. I had bunch of small problems but that didn’t stop me down; squeaky brake, bad contacts, key switch problem, slipping clutch… but al that is normal and it wasn’t so hard to find and fix… but now I have bigger problem.
From time to time I have “power cut of” around 4000rpm and there is change in sound. My conclusion is that one cylinder is taking a “brake”. Again my assumption is that root of all troubles is in curbs; they are not returning properly and mix is too hard (gas smell). Also there is back firing from time to time and I cant solve that problem- put new 8ES plugs, points are new and gap is set same 014. So if timing is ok and there is a spark, plus all elements are new, my only conclusion is that carbs are to blame.
I removed a top from carburetors and they look OK but I don’t know what is inside… my problem is that am not familiar with this carb’s (and CB 450 I general) can you pleas help me with this so I can have couple more days of riding before Montreal winter kick me back to a garage in to a café project. thanks I advance
