Tried to swap Lester mags (drum rear style ) from a '77 CB 750 to my '73 cb 450...NFG! The sprocket flange (or whatever you call the assembly that fits into the cush drive) is too wide. Everything else is a go. Does anybody know if a flange from a another size CB might be narrower AND fit the cush drive of the 750 rim? The brake backing plates interchange,so it is not outside the realm of possibility that there is a flange out there that will work for me. If I can't get the Lesters to work,off to ebay they go!Then I shall continue my exercise in futility with a set of Comstars from an '82 450 Nighthawk.Does anyone know if the Comstars are a viable option for use on my '73 CB 450?My goal is to end up rims that can be run with tubeless tires.Any insight will be greatly appreciated!
Dan
Dan
