CB 550 Carb Trouble
phrige
I'm a pig, I'm A dog so exuse me if I drool.
Hi all,
So i just picked up a 1975 CB550. The two main problems I'm having is a loose wire somewhere which I gatta track down (prevents it from starting up). Main problem is the Carbs. The previous owner had them rebuilt about a year ago but hasn't really been ridden much since, just sat in the garage. Out of the 4 carbs on the bike it seems that potentially two have a problem of when I try starting I place the fuel control from Off to ON, it takes maybe 30 secs then two of the carbs start discharging a steady stream of fuel. It seems like one is strong stream and the other intermittenly releases Fuel from the excess discharge. Once the bike is running it doesn't leak or as noticibly leak. I was wondering if anyone had any ideas or advice for this situation. Should I rebuilt all the carbs, or just the two problem ones? full rebuild or just cleaning them out?
Any ideas are appreciated
Peter
Float sounds stuck or float pin broke or possibly overflow metal tubes inside the float bowl could be cracked. I'd pull the petcock off and clean it out, pull the bowls off the carbs and see if the floats are free and if you have a mirror, check to see if the float pins are there and working properly (I've seen them completely missing). It's usually worth pulling the carb assembly off and cleaning the hell out of them, maybe rebuilding them with new seals and jets and at least setting the float levels.
When I bought my 550, the exact same scenario was going on. Mine was a broken float pin so it never stopped filling and while you should turn the petcock off after shutting the bike off, you should have to deal with fuel flowing out of the overflow tubes if you don't :)
Thank you for your help. I just got back from a camping trip in the pine barrens so I haven't had a chance to check the message board. But sure as hell bet this is the next thing I'll be doin. : )
Thanks Brother,
Peter
