CB/CL 175 carb question
facefirst35
Coast to Coast
I've acquired a CL175 and the left carb top is cracked. Does anyone know if carbs from a CL200 would be a direct replacement for the 175 carbs or if the top part will at least screw right on to the 175 carb? Thanks in advance!
I believe the carbs are 2 different sizes. So the parts probably won't interchange. If the mounts on the head are the same, they might bolt right up.
How bad is the crack? You may be able to repair it with JB Weld or Alumiweld. Post a pick.
I picked up a set here at DTT for $35 today. I'm hoping that the top set part will at least be the same size so I can replace it.
DJ, I guess cracked is an understatement. It's in about 3 pieces. I bought the bike that way. So hopefully the top set will at least be interchangeable. We shall see when I get it. Worst case is it doesn't fit and I sell the carbs.
