CB/CL350 Carb questions/missing parts
fluke12
1972 CL350
Two things,
I opened my carbs up to see the bottom of the choke valve missing just underneath the relieve valve. I can take a picture if it'd help you guys, but its pretty much what you imagine, just a small gap. Is it possible to just replace these? am i going to have to find another set of carbs just to get the choke valves? Is it even an issue i should be worrying about?
And two, anyone know where I can get the same jet holders gomotomoto needed?
http://www.dotheton.com/forum/index.php?topic=31019.0 Its the jet holder i'm looking for, i only need one.
Thanks
Looks like Sirus consolidated with premium carb re-build kit.
Bit expensive but still way cheaper than VM's plus all the extra jets you need to get them working
It's real common for the bottoms to be broken off, they look like screw in discharge tubes but are really press in, the slot is to allow fuel flow from primary main jet
