CB/CL450 Drum Brakes & Parts
NA3S
I've just started on a CL450 build and am parting out several of the components I won't be using....
The parts listed correlate to the numbered photos.
2) 40 hole, 200mm DLS, CB/CL450 front drum brake hub. Includes the hub, brake plate, brake linkage, axle, and speedo drive. Will need to be cleaned/polished but there is no damage or major scratches/gouges/knicks/etc; it should clean up just fine. These front drums are very powerful and as such are highly sought after by those in vintage class racing....$150
3) 40 hole, 200mm DLS, CB/CL450 front drum brake hub. This one is just the hub and axle. Will need to be cleaned/polished and the inner drum would benefit form a visit to the blasting cabinet but there is no damage or major scratches/gouges/knicks/etc; it should clean up just fine. These front drums are very powerful and as such are highly sought after by those in vintage class racing....$100
For more info about these front drum hubs - http://www.vintagebrake.com/drumspec.htm
4) 40 hole rear CB/CL450/CB500t drum brake hub. Includes the hub, brake plate, brake linkage, axle, tensioners, and rear sprocket. Will need to be cleaned/polished but there is no damage or major scratches/gouges/knicks/etc; it should clean up just fine. $50
5) 40 hole rear CB/CL450/CB500t drum brake hub. Includes the hub, brake plate, brake linkage, and rear sprocket. Will need to be cleaned/polished but there is no damage or major scratches/gouges/knicks/etc; it should clean up just fine. $50
6) CL450 rear swingarm, brake stay, and chain guard. The entire unit will need new paint and the chain guard has snapped at the rear mounting point but would be very easy to reweld, as pictured. $40
In addition to these parts, I also have 5 stock steel 40h rims drilled for these large drum hubs. They're all usable but will require sand blasting/powder coating due to surface rust in the chrome and minor knicks... $25-40 each
-2x 18" front
-2x 18" rears
As well as one set of carbs that will need to be rebuilt but are complete, all butterflys and slides move freely...$65
I'll be getting pictures of these parts in the next day or two.
I accept paypal and will ship at buyers expense.
