CB/CM400 Guys HELP!
Maritime
Over 10,000 Posts
OK, I blew my motor :'(, more specific I had an oil issue in the right cylinder and melted it, bent the rod, scored the walls etc. Bike is stripped down to frame, going to rebuild comepletely. Here is the question, how do I prevent the same motor issue again? I had the proper amount of oil in, when I pulled apart the motor I checked the tolerances on the oil pump, it is fine, the oil channels seemed ok, there was lots of oil in the head/cam area on both sides? I don't want to rebuild or replace the motor only to have the same issue. Is there anything else I am missing? The oil pump was missing the gasket. Could that have done it? As were the side covers, they had silicone squeezed around the outside. One thought I did have after reading on the net was to get the 82+ 450 out of the night hawk as it looks like it will bolt right in and they re-inforced the engine, added a gear and an oil tube to get oil to the head. There are a lot fo people on this site who have the same kind of bike and know a lot mre than me. I would love to know what I can do to prevent this and if you guys think the 82+ motor would be a good option. I found a parts bike about an hours drive away for 500 that is running and complete minus battery and good tires, which I have. I just don;t want to buy it, then crap the motor. What is the best preventative thing I can do to keep my motor alive?
Any help would me much appriciated. Oh and I will take some pics and post once the rebuild starts this weekend.
Thanks
Maritme Biker
Well, I'm pretty sure you've already answered your own primary question...
You told us there was SILICONE in some areas, instead of a real GASKET; morons and ASSHOLES use silicone as gasket material when they're too CHEAP (or too STUPID) to buy (or fabricate) a gasket where a REAL gasket is REQUIRED! The NEXT thing they do is, they SELL the bike to some guy who doesn't know that there is silicone sealant in the engine. Sooner or later, the silicone starts to break down, and the NEXT thing you know, an engine gets DESTROYED because a little piece of silicone is blocking an oil passage in the engine!
If you can get a new(er) engine (you mentioned the '82+ 450cc engine) and install that, you'll be ahead of the game. I wouldn't want to risk rebuilding that original engine, knowing that there could be MORE silicone in the oil jacket... so don't take the chance. The 450 Nighthawk engine SHOULD work just fine for you, so I'd consider that to be your absolute best option; just hope that any replacement engine you find wasn't also buggered up with silicone sealant, or you'll be swapping the engine AGAIN, sometime in the future.
Others might have different advice for you, so keep an open mind about this; MY advice is, find a GOOD replacement engine, and dismantle the old one. Sell the usable parts here, or online somewhere else, but do whatever it takes to make sure that buggered engine never comes back from the dead to haunt you, or anyone else...
Good luck with this; sorry you had to lose an engine to find out WHY silicone shouldn't be used around internal oil (or other fluid) passages, but this will be a lesson to anyone who reads this thread in the future. Hope you can find a suitable engine without a lot of fuss and heartburn...
Thanks Kneedragger, I didn't like seeing the silicone and read in the repair manual that you should't use it. I didn't really know why, but now I do. I am hopefully going to look at the engine in the 82 this weekend and believe me I will check it head to base for silicone on any engine part. Crappy way to learn but hey it was my first bike and I didn't pay much for it. I will still be under fair marklet value even after swapping in a new-used motor. I am looking at it this way, I lost about 3 weeks driving time but gained 3 weeks on the rebuild.
Cheers
